jkmchow
3 years agoerrors found while generate project in "nios II build tools for eclipse"
I am using Quatus Prime Lite 17.1. In Nios II build tool for eclipse, two files were made, "embed" and "embed_system.bsp", of which the build project was done successfully. However, to build project...
- 3 years ago
Could you try using the Nios II SBT design template, and select the Hello World template. Then, you should regenerate a new BSP to see the mismatch of names come from the new BSP, or you were using the old BSP generated with the wrong name.
Also, what is the FPGA development kit you are using for your project?
Hope this helps.
Thank you.
Regards.
Kelly
KellyJialin_Goh
3 years agoHi,
Any feedback from your end? Have you managed to eliminate the errors after adding the correct IP names?
Thank you.
Regards.
Kelly
- jkmchow3 years ago
Hello Kelly,
I have been trying all possible ways to eliminate the errors. There is still no luck.
Thank you for your attention.
Joseph
