jkmchow's avatar
jkmchow
3 years ago
errors found while generate project in "nios II build tools for eclipse"
I am using Quatus Prime Lite 17.1. In Nios II build tool for eclipse, two files were made, "embed" and "embed_system.bsp", of which the build project was done successfully. However, to build project...
  • KellyJialin_Goh's avatar
    3 years ago
    Could you try using the Nios II SBT design template, and select the Hello World template. Then, you should regenerate a new BSP to see the mismatch of names come from the new BSP, or you were using the old BSP generated with the wrong name.
    Also, what is the FPGA development kit you are using for your project?
    Hope this helps.
    Thank you.
    Regards.
    Kelly
