errors found while generate project in "nios II build tools for eclipse"
- 3 years ago
Could you try using the Nios II SBT design template, and select the Hello World template. Then, you should regenerate a new BSP to see the mismatch of names come from the new BSP, or you were using the old BSP generated with the wrong name.
Also, what is the FPGA development kit you are using for your project?
Hope this helps.
Thank you.
Regards.
Kelly
Have you tried adding in and naming it as jtag_uart in platform designer? You may follow the user guide here: https://www.intel.com/programmable/technical-pdfs/683689.pdf Section 3.6.5.5.4. Add the JTAG UART
If the issue still persists, it is recommended you update the Quartus version used to avoid errors.
Thank you.
Kelly
Hello Kelly,
I am designing the Nios II for a course assignment, one requirement of which is to use the "sdram controller IP". Only the Quartus Prime Lite 17.1 supports this IP. Unless there is a way to add this IP in the other more updated versions of Quartus Prime Lite, my assignment will be stucked.
Thank you for your attention and help.
Joseph
