errors found while generate project in "nios II build tools for eclipse"
- 3 years ago
Could you try using the Nios II SBT design template, and select the Hello World template. Then, you should regenerate a new BSP to see the mismatch of names come from the new BSP, or you were using the old BSP generated with the wrong name.
Also, what is the FPGA development kit you are using for your project?
Hope this helps.
Thank you.
Regards.
Kelly
Greetings and Welcome to Intel's forum.
You may follow the steps in the embedded design handbook to add the system ID peripheral at section 3.6.5.5.6. (Add the System ID Peripheral): https://www.intel.com/programmable/technical-pdfs/683689.pdf
Let me know your feedback and whether the above suggestion was helpful.
Thank you.
Kelly Jialin
- jkmchow3 years ago
Hi, Kelly,
Thanks for the information. I have followed your suggestion and followed every details. However, I got the same error messages.
Joseph
