12 years agoA logic loop is when X = f(A,X), ie. the output is a function of itself. So I assume you have generated a couple here.
Is there any reason you have not created a synchronous circuit?A logic loop is when X = f(A,X), ie. the output is a function of itself. So I assume you have generated a couple here.
