9 years agoError:Port "cg" does not exist in macro function "ADD0"
So i got 8 error while compiling this 4 bit Carry-lookahead adder. I got the above error for ports cg and cp in macro functions ADD0-ADD3. For my code check the attachments. Edit: Here i've copied the code in:
--- Quote Start --- library IEEE; use IEEE.std_logic_1164.all; entity cla4 is -- 4-bit CLA structural model: top entity port( a, b: in std_logic_vector(3 downto 0); carryin: in std_logic; sum, ch, cq: out std_logic_vector(3 downto 0); cgout, cpout, overflow: out std_logic); end cla4; architecture arch of cla4 is component fagp -- component declaration port( a, b, cin: in std_logic; sum, cg, cp: out std_logic); end component; component cla_logic -- component declaration CLA-generator port( g, p: in std_logic_vector(3 downto 0); cin: in std_logic; c: out std_logic_vector(2 downto 0); cgout, cpout: out std_logic); end component; signal carry: std_logic_vector(3 downto 0); --local signals signal cg, cp: std_logic_vector(3 downto 0); signal cout: std_logic; begin carry(0) <= carryin; ADD0: fagp port map (a(0), b(0), carry(0), sum(0), cg(0), cp(0)); ADD1: fagp port map (a(1), b(1), carry(1), sum(1), cg(1), cp(1)); ADD2: fagp port map (a(2), b(2), carry(2), sum(2), cg(2), cp(2)); ADD3: fagp port map (a(3), b(3), carry(3), sum(3), cg(3), cp(3)); --generate carries from --propagate and generate values --from full_adder_g_p_g_p CLA: cla_logic port map(cg, cp, carryin, carry(3 downto 1), cout, cpout); cgout <= cout; overflow <= carry(3) xor cout; end arch; --- Quote End --- --- Quote Start --- library IEEE; use IEEE.std_logic_1164.all; entity cla_logic is port( G, P: in std_logic_vector(3 downto 0); CIN: in std_logic; C: out std_logic_vector(2 downto 0); -- “internal” carry CGOUT, CPOUT: out std_logic); end cla_logic; architecture arch of cla_logic is begin C(0) <= G(0) or (P(0) and CIN); C(1) <= G(1) or (G(0) and P(1)) or (CIN and P(0) and P(1)); C(2) <= G(2) or (G(1) and P(2)) or (G(0) and P(1) and P(2)) or (CIN and P(0) and P(1) and P(2)); CGOUT<= G(3) or (G(2) and P(3)) or (G(0) and P(2) and P(3)) or (G(0) and P(1) and P(2) and P(3)) or (CIN and P(0) and P(1) and P(2) and P(3)); CPOUT<= (P(3) and P(2) and P(1) and P(0)); end arch; --- Quote End --- --- Quote Start --- library IEEE; use IEEE.std_logic_1164.all; entity fagp is port( a, b, cin: in std_logic; sum, g, p: out std_logic); end fagp; architecture arch of fagp is begin sum <= a xor b xor cin; p <= a and b; --complete this g <= a or b; --complete this end arch; --- Quote End --- Any Ideas??No RepliesBe the first to reply
