Shwetha_G_S
3 years agoError:Fitter cannot place 2 periphery component(s) due to conflicts with existing constraints 2 pins
We use "10AS048E3F29I2SG" device, and in our hw design,FPGA uses shared I/O as following:
FPGA_RTC_FAN_SENSOR_SDA @D20 (SHARED_Q1_5) FPGA_RTC_FAN_SENSOR_SCL @E20 (SHARED_Q1_6)
We are tryi...
sstrell
3 years agoAre these pins part of some IP that is making these pin location assignments itself? Have you tried removing the manual Pin Planner assignments you made as noted?
- Shwetha_G_S3 years ago
Hello Sir,
We have tried with removing pin planner assignments also,same error exists(fitter error).
FPGA_RTC_FAN_SENSOR_SDA and FPGA_RTC_FAN_SENSOR_SCL pins are not part of IP and it is not taking pin location itself.We are assigning pins in pin planner according to our hardware.
Please give a solution for this.
