MamaSaru's avatar
MamaSaru
2 days ago
Error(13135): Address/command pin is constrained to an illegal location
I got strange error message from fitter.
Error(13135): Address/command pin (ddr3_a[0]) is constrained to an illegal location (PIN_AG19). The legal location for this pin is PIN_Y17
As the error message said, I set the location assignment to ddr3_a[0] at PIN_AG19, it is because the device documentation said to do so.
It seems that the error message mistakenly guides a[0] pin to PIN_Y17, in the documentation this PIN_Y17 is the legal location of a[14] .
Here is my environment:
Quartus Prome Pro 23.2 on Windows 11
External Memory Interfaces Intel Cyclone 10 FPGA IP, altera_emif_c10 19.1.1
Cyclone 10 GX FPGA Development Kit (Power Solution 1) DK-DEV-10CX220-A
Cyclone 10 GX 10CX220YF780E5G
Below is my study about this problem:
1. The error reports also that ba[2:0] locations are illegal not only for a[14:0].
2. When I make a[] and ba[] location be free, the fitter places a[0] to PIN_Y17 .
3. If I connect reverse bit order, like a[14] to a[0] and so on, it fits successfully. (for ba[] too.)
4. In my thought, in placing reverse order, it may not work correctly because the MRS cycle uses address pin to send data for mode register.
5. I checked my design that the IP's mem_a[] outputs is connected to Device's ddr3_a[] pins without reversing.
6. The generated example design can fit without strange error message.
7. I made small project to reproduce this problem.
8. My reduced design has top level SystemVerilog file and one step low level of block design file.
9. I changed the hierarchy top level sv design file to one level lower bdf design file for a trial, it can fit to normal location as on documentation.
10. I rewrite the top level SystemVerilog design to VHDL, AHDL, Block design, all three rewrite versions can fit to normal location as on documentation.
I can disclose small project to reproduce this problem.
Thank you for your help.
Masaru
1 Reply
  • Hello Masaru
    There is DDR3 example design targeting Cyclone10GX devkit(version B) and see no fitter error with placing ddr3_a[0] at PIN_AG19.
    Please download the DDR3 design from below link.
    c10gx-10cx220yf780-revb-v22.4b94-v1.0\examples\ddr3x40
    https://docs.altera.com/v/u/resources/838158/cyclone-10-gx-fpga-development-kit-version-b-dk-dev-10cx220-b-installer-package-v22.4-or-higher
