Error(11176): quartus\bin64\ccl_ver_jni_stub.dll: Can't find dependent libraries
Hi @VFlav
That might be one of the possible root cause as the Intel Quartus Prime Standard and Pro Editions are no longer supported under Windows 7 and replaced with Windows 10. Reference:
If possible, try to upgrade to Window 10 and check if the issue persists.
Richard Tan
Unfortunately, I can't upgrade to Windows 10 version because my computer is for professionnal purpose.
Have you any other leads to solve this issue ?
Thanks in advance for your help,
Vincent
- RichardT_altera5 years ago
Hi @VFlav
You may try to install the Quartus in a different machine with supported OS. Or run Quartus in a virtual machine, as a workaround.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos. - VFlav5 years ago
I downgrade Quartus Prime Pro to 19.1 and IP generation for the debug fabric is done correctly
Unfortunately, the problem remains in version 19.4 and 21.2
Vincent
Hi @VFlav
Do you have a simplified design that could duplicate the error?
I will try to duplicate it from my side.
Richard Tan
I reuse this part of code for SFP+ driving and JTAG debugging. These two blocs are present on several project, and all of them generate the same error.
Vincent
Hi @VFlav
Could you share me the .qar file? You can generate it by go to Project > Achieve Project.
Richard Tan
Unfortunately, I can't share any project because of industrial copyright.
But I don't think this error occur in a particular project. Maybe, this a consequence for using Platform Designer (or directly qsys)
Thanks for your help,
Vincent
Hi @VFlav
Most of our customer able to open Platform Designer and do not faced this specific error so I can only suspect that there maybe something wrong with the Quartus installation or your machine/OS requirement does not support.
Since you are able to use Quartus Pro 19.1 then I would recommend to use that current version for now.
Otherwise, the community users here that come across similar issue may help you on this thread.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos. - RichardT_altera5 years ago
I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
