Ok!, But i think i don't need a process...i putted it cause i saw in a thread....
And if i put:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
library std;
use std.standard.all;
entity Calculador is
port( a : in std_logic_vector (3 downto 0);
b : in std_logic_vector (3 downto 0);
Selop : in std_logic_vector (1 downto 0);
z1 : out std_logic_vector (3 downto 0);
z2 : out std_logic_vector (3 downto 0));
end Calculador;
architecture a of Calculador is
begin
with Selop select
z1 <= a when "00",
a when "01",
b when "10",
a when "11";
z2 <= b when "00";----->this line
a when "01";------>this line
b when "10";------>this line
b when "11";
end a;
I get the error: Error (10500): VHDL syntax error at opc.vhd(THESE LINES) near text ","; expecting ";"
Do i need a process? or i'm doing wrong other things?
Thank you to answer so fast
