11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
10 years agoGiven the space in the variable, maybe you need to use inverted commas, e.g., env CL_CONTEXT_EMULATOR_DEVICE_ALTERA="de1soc_sharedonly vector_add"
Is this a possibility?
