11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
10 years agoHi Paulo,
Using Windows' command prompt should do the trick. Why not try to setup the CL_CONTEXT_EMULATOR_DEVICE_ALTERA environment variable directly using Windows' GUI: right-click on My Computer, Properties, Advanced system settings, environment variables, etc. Doing so will avoid you to have to set it in the execution command. Regards, David
