11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
10 years agoHi thach.david
The executable file (vector_add) is generated afer compiling. I run the geneared file in Altera Embedded_Command_Shell or in Windows Command Prompt? Regards, Paulo
