11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
10 years agoHi dutiene,
I cannot say much based on the limited information you shared here but it really seems like the problem has nothing to do with AOCL and rather be related to the fact that the executable (vector_add) is simply not there. I am not familiar with this "de1soc" board you are using but I would recommend you to start with recompiling the executable file and then try the execution command once more. Regards, David
