11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
10 years agoHello , I am using Windows 10 and am having the same problem. I am running as follows:
du_ti@DESKTOP-BDFRAF0 /cygdrive/c/altera/15.0/hld/board/de1soc/examples/vector_add $ env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=1 vector_add env: vector_add: No such file or directory I also tried the following: $ env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=de1soc_sharedonly vector_add How do you solve your problem?
