11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
11 years agoHi there,
This post is a bit old so you probably already solved the problem but just in case: while typing the command, make sure not to put spaces on either sides of the "=" sign. The command should work then. Regards, David
