11 years agoError with command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA
I'm using emulation on Linux and run the application with the command "env = CL_CONTEXT_EMULATOR_DEVICE_ALTERA s5_ref vector_add" I get the following message: "env: CL_CONTEXT_EMULATOR_DEVICE_ALT...
11 years ago --- Quote Start --- To run the application, invoke the command env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=<board_name> <your_host_program_name>, where <board_name> is the FPGA board name you specified when you compiled your kernel. You've got the equal sign in the wrong place. --- Quote End --- I'm sorry, I typed wrong here in fact, the command is: env CL_CONTEXT_EMULATOR_DEVICE_ALTERA = <board_name> <your_host_program_name> the error message is the one that talked about earlier
