temp1234
3 years agoError while trying to run Questa simulator
I think this is related to a licensing error, that I'm not sure how to remedy, but I just installed Quartus (Lite edition) and Questa. And quartus seems to compile a simple module and testbench modu...
RichardT_altera
3 years agoThank you all for the feedback provided on this issue.
The engineering team has aware of this issue and they will plan to fix this. (usually will takes some time depending on the issue complexity)
Since this issue will be planned to be fixed and a workaround is available, do you need further help in this case?
Richard Tan
