temp1234
3 years agoError while trying to run Questa simulator
I think this is related to a licensing error, that I'm not sure how to remedy, but I just installed Quartus (Lite edition) and Questa. And quartus seems to compile a simple module and testbench modu...
RichardT_altera
3 years agoHi,
Do you able to resolve the issue based on the solution provided by the community?
Richard Tan
- NickWilliams3 years ago
I also had this problem; please escalate this as a fault with the Quartus engineering team. It's very clearly a bug in the TCL code that would affect any attempt to launch Questa FSE from the menu in 22.1/Lite version of the product.
nhw@MBP16:/mnt/c/intelFPGA_lite/22.1std/quartus/common/tcl/internal/nativelink$ diff -c qnativelinkflow.tcl.old qnativelinkflow.tcl *** qnativelinkflow.tcl.old 2022-12-07 15:38:42.897669900 -0500 --- qnativelinkflow.tcl 2022-12-07 15:39:35.472632200 -0500 *************** *** 119,125 **** } else { set questa_fse_directory "$quartus_path/../questa_fse" if {[file isdirectory $questa_fse_directory]} { ! set questa_installation "$questa_fse_directory set found_a_questa_installation 1 } } --- 119,125 ---- } else { set questa_fse_directory "$quartus_path/../questa_fse" if {[file isdirectory $questa_fse_directory]} { ! set questa_installation "$questa_fse_directory" set found_a_questa_installation 1 } }
