Altera_ForumHonored Contributor13 years agoerror while simulating in quartus Hi, I'm trying to simulate a FSM, but I keep getting this error message: "Error: Zero-time oscillation in node "|top|FSMcontrol:L1|Selector5~0" at time 50.0 ns. Check the design or vector sour...Show More
Altera_ForumHonored Contributor13 years agoatraso <= atraso + 1; you cannot put counters in an asynchronous process.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
