10 years agoError while executing: Force
Hello all, I recently installed ModelSim, and am having all sorts of issues with it. I am trying to simulate a project that contains several Altera IP cores (counter, ROM, PLL, ALTDIDO) and am ...
10 years agoSo, I've cleaned out anything that was VHDL in the project, including some old vhdl.do files. Additionally, I renamed anything in the path of the project/simulation that had spaces in the directory name. Now, it appears there are no errors on startup of ModelSim. However, if I select "simulate" on one of the IP cores in my design, I get the following:
ModelSim> vsim work.TX_PLL_altpll
# vsim work.TX_PLL_altpll
# Start time: 16:40:32 on Feb 22,2016
# ** Error: Failure to obtain a Verilog simulation license. Unable to checkout any of these license features: alteramtivsim or alteramtivlog.
# Error loading design
# End time: 16:40:32 on Feb 22,2016, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0 Do you still think this is a VHDL error? Is there any way I can find the offending vhdl file so I can remove it?
