16 years agoError while creating a project using Nios II Software Build Tools for Eclipse
I am running quartus2 and nios2eds in windows. i was unable to Create a New Nios II Application and BSP from Template. the error was unable to create project Reason: Failed to...
14 years ago --- Quote Start --- Thank you. I tried it but it is still not working --- Quote End --- Try sharing the project folders with everyone. I'm using Windows7 so I right-click on the top level project folder and select Sharing/Homegroup(Read/Write). Make sure the sharing caries down through the sub-folders.
- sathvik3 years ago
Worked! Thank you!!
