16 years agoError while creating a project using Nios II Software Build Tools for Eclipse
I am running quartus2 and nios2eds in windows. i was unable to Create a New Nios II Application and BSP from Template. the error was unable to create project Reason: Failed to...
16 years agoI have the same problem . The appeared problem is :
unable to create project Reason: Failed to execute: ./create-this-bsp -- cpu name cpu_0 --no-make Kindly advise. Your prompt reply is highly appreciated
