rewingchow
5 years agoError When Creating Project in Platform Designer in Quartus Prime Pro 19.3
Error: Failed to create Quartus Project, manually re-run the commands included in /hard_drive/randy/pigasus/hardware/scripts/quartus_sh_tcl_file_for_qsyspro.tcl in Quartus tcl shell.
Occurs when c...
- 5 years ago
Hi @rewingchow
Since you mentioned that Quartus 20.1 and onwards are fine, I would recommend that you upgrade your project to the latest Quartus version 21.2 to check if the issue still persist.
We have fixed a lot of bugs with the latest Quartus version.
Richard Tan
rewingchow
5 years agoI can do that, it only does not work when creating through Platform Designer. I need this method to work as it allows for my tcl script to work.
sstrell
5 years agoWhy are you referencing 18.0 as the version at the top of your script? Maybe that's the issue.
