AvramG
4 years agoError: (vsim-3173) Entity '...' has no architecture.
Hi.
I intend to work on Cyclone10 chip. I try to do a simulation on 1-port RAM IP in Questa.
When I run my compile_async_player.do file with the following commands:
vcom -stats=non...
ShengN_altera
4 years agoHi,
After I replace the simulation_bad file msim_setup.tcl script with the one in simulation_good file, simulation_bad file can be simulated properly.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- AvramG4 years ago
Hi Sheng,
Thanks for your help.
I replaced the msim_setup.tcl file and I got the same eror:
# Loading work.async_input_bram_player_tb(testbench)#1
# ** Error: (vsim-3173) Entity 'C:/svn/exo_r_c10gx/Altera_community/simulation_bad/libraries/work.async_input_bram_player' has no architecture.Could you upload your simulation_bad directory (after the fixing)?
I want to compare with mine.
Avram
