8 years agoError: (vsim-3033) Instantiation of 'alt_dual_boot_avmm' failed.
Hi there I am have a severe and persistent problem with an attempt to simulate a MAX10 Qsys (platform designer) system in Modelsim. Everytime I try to run an RTL simulation from the synthesized...
8 years ago --- Quote Start --- I'm presuming you have generated the system in Platform Designer or performed at least synthesis to have the system design files generated. Also, you mention ModelSim. Are you using ModelSim-Intel FPGA edition or stand-alone ModelSim (SE or PE)? If you are using stand-alone ModelSim, you have to set up the IP simulation models to get compiled in the tool. The Intel edition has all this pre-compiled. --- Quote End --- Hello and thank you for the reply. I have generated the VHDL using platform designer as well as synthesized the complete design with Quartus. I have also generated the simulation libraries. I am aware of the pre-compiled libraries in Modellsim-Intel FPGA edition, but I do not believe this to be an issue related to those as I have attempted this simulation using ModelSim-Intel FPGA edition, ModelSim PE and Questa Prime. All three simulation packages give the same error.
