17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
16 years agoI think this relates to th OPs problem. There seems to be a typo in the supplied file from Altera as part of DE2_tutorials\design_files data set has the top level entity/arch named addersubtractor2 in addersubtractor.vhd, it should of course be addersubtractor the file is marked (C) 2005 Altera Corporation.
as shown here: -- Top-level module ENTITY addersubtractor2 IS GENERIC ( n : INTEGER := 16 ) ; PORT ( A, B : IN STD_LOGIC_VECTOR(n-1 DOWNTO 0) ; Clock, Reset, Sel, AddSub : IN STD_LOGIC ; Z : BUFFER STD_LOGIC_VECTOR(n-1 DOWNTO 0) ; Overflow: OUT STD_LOGIC ) ; END addersubtractor2 ; ARCHITECTURE Behavior OF addersubtractor2 IS..... This section of the file should read (as it did in 8.0sp1 supplied files): -- Top-level module ENTITY addersubtractor IS GENERIC ( n : INTEGER := 16 ) ; PORT ( A, B : IN STD_LOGIC_VECTOR(n-1 DOWNTO 0) ; Clock, Reset, Sel, AddSub : IN STD_LOGIC ; Z : BUFFER STD_LOGIC_VECTOR(n-1 DOWNTO 0) ; Overflow: OUT STD_LOGIC ) ; END addersubtractor ; ARCHITECTURE Behavior OF addersubtractor IS..... This file is marked -- (C) 2004 Altera Corporation. All rights reserved. Looks like a typo possibly, but if you change the top level entity and architecture to match as shown it will compile ok. Not helpful for beginners!
