15 years agoError: The pin "data[5]" has multiple drivers due to the constant driver
Im kinda new with Quartus II and VHDL so let's go. Im projecting a simple CPU. with 4 registers. so i have 2 signals to let the register (normal_buffer) read from the bus or right. those signals are Rin and Rout. i made a MUX to select who is reading or writing on the given state. When i trie to compile i get the error "Error: The pin "data[5]" has multiple drivers due to the constant driver" this error happens when i do this " sel_code_rout <= "110"; " what this error means? what im doing wrong? thank you very much Observation: Please ignore the coments that are not in english. =D
library ieee;
use ieee.std_logic_1164.all;
LIBRARY CPU;
USE CPU.ula_package.all;
ENTITY CPU IS
port( input: in std_logic_vector(7 downto 0);
clock: in std_logic;
reset : in std_logic;
data: INOUT std_logic_vector(7 downto 0);
output: out std_logic_vector(7 downto 0)
END CPU;
ARCHITECTURE test of CPU is
type state is (A,B,C,D);
signal s : state;
signal Rin,Rout : std_logic_vector(0 to 6);
signal r1,r2,r3,r4,Y,Z,RI: std_logic_vector(7 downto 0);
signal zero: std_logic;
signal control: std_logic_vector(1 downto 0);
signal sel_code_Rin,sel_code_Rout,sel: std_logic_vector(0 to 2);
signal conta : std_logic_vector(7 downto 0);
signal i : std_logic;
begin
P_C : PC port map(data,i);
reg1: normal_buffer port map(data,Rin(0),Clock,r1);
reg2: normal_buffer port map(data,Rin(1),Clock,r2);
reg3: normal_buffer port map(data,Rin(2),Clock,r3);
reg4: normal_buffer port map(data,Rin(3),Clock,r4);
reg_Y: normal_buffer port map(data,Rin(4),Clock,Y);
reg_RI: normal_buffer port map(data,Rin(5),Clock,RI);
tri_state_1: tri_buffer port map(r1,Rout(0),data);
tri_state_2: tri_buffer port map(r2,Rout(1),data);
tri_state_3: tri_buffer port map(r3,Rout(2),data);
tri_state_4: tri_buffer port map(r4,Rout(3),data);
tri_state_Y: tri_buffer port map(Y,Rout(4),data);
tri_state_RI: tri_buffer port map(RI,Rout(5),data);
--LIGACAO FEITA. FAZER AS CONTAS!
unidade_logica: ULA port map(Y,data,control,zero,conta);
reg_Z: normal_buffer port map(conta,Rin(6),clock,Z);
tri_state_Z: tri_buffer port map(Z,Rout(6),data);
--seleciona qual registador vai escrever no barramento
with sel_code_Rin select
Rin <=
"1000000" when "000", --R1
"0100000" when "001", -- R2
"0010000" when "010", -- R3
"0001000" when "011", --R4
"0000100" when "100", --Y
"0000010" when "101", --RI
"0000001" when "110", -- Z
"0000000" when others;
-- seleciona qual registrador vai receber dados do barramento
with sel_code_Rout select
Rout <=
"0001000" when "011",--R4
process (data,reset,clock)
begin
if reset = '0' then
s <= a;
elsif (clock'event and clock = '1') then
case s is
when A =>
sel_code_Rin <= "101";
i <= '1';
output <= "00000001";
s <= B;
when B =>
--sel_code_rin <= "111";
i <= '0';
case RI(7 downto 5) is
when "000" =>
output <= "00000000";
when "001" =>
output <= "10000001";
s <= C;
when "010" =>
output <= "00000010";
when "011" =>
output <= "00000011";
when "101" =>
output <= "00000101";
when "100" =>
output <= "00000100";
when others =>
output <= "00000111";
end case;
when C =>
--FAZER RIN E ROUT!
sel_code_rin <= "100";
sel_code_rout <= "110"; <= WHEN I DO THIS I GOT THE COMPILER ERROR!
s <= D;
when D =>
control <= "00";
when others =>
output <= "11111111";
--sel_code_rout <= "111";
s<= A;
end case;
end if;
end process;
end test;
