fschu12
7 years ago[Error] Quartus not find while ./install_openvino_fpga_dependencies.sh script - Intel® Arria® 10 FPGA (IEI's Mustang-F100-A10)
I get a "Quartus not find" Error on executing the ./install_openvino_fpga_dependencies.sh script. I manually downloaded and installed the Quartus software "Quartus-lite-18.1.0.625-linux" but I still ...
YTsen4
7 years agoFinally, I found the problem is that I did not provide enough power to my FPGA board.
Then, the problem is solved by utilizing a external power supplier.
However, the same error message popped up and it is solved by typing sudo updatedb
When I followed the instructions in the following link:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_VisionAcceleratorFPGA_Configure_2019R1.html
I am a little bit stuck at the first part of step 14.
- Could you please tell me why do I need USB Blaster?
- Aren't the programs in the FPGA board had been already burned into it?
- Will it affect the DL model which I want to accelerate?
Thanks a lot for your help!
Best,
Charlie
