BMark2
7 years agoError: one_0.cpu_one: Multiplier selected is not compatible with selected device and design type
Hi everyone! I'm trying to implement multiprocessor system design explained in Multiprocessor Nios II System Tutorial(https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_n...
BMark2
7 years agoHello Abe!
Thanks for your replying!
I'm using Qsys / Platform designer files provided in the example. When I was starting to add soft CPUs to the main system Qsys started complaining about incompatible multipliers. I checked NIOS 2 CPU and the frequency is 50MHz as it was recommended by the tutorial. By the way, the compilation of the file worked nice but adding soft CPUs to the system caused incompatibility errors. Yes, the device setup is also changed so everything is fine in the setup.
Regards/
