BMark2
7 years agoError: one_0.cpu_one: Multiplier selected is not compatible with selected device and design type
Hi everyone! I'm trying to implement multiprocessor system design explained in Multiprocessor Nios II System Tutorial(https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_n...
Abe
7 years agoAre you using the Qsys / Platform designer files provided in the example or building your own from scratch? I suggest you select the NIOS CPU in the system and check the frequency settings, Make sure the frequency is within operating range of the MAx10 FPGA your're using. Did you also change the Device setup in the main project settings?
