Error on Quartus Prime Startup
When I try to run Quartus Prime Lite 18.1 on my PC, I see the splash screen and then the program fails to load after about 30 seconds. Each time I attempt to run the software, cr_ie_info.json is updated in C:\intelFPGA_lite\18.1. This file is attached (I had to change the file extension to be able to upload to the site). Based on the information in this file, it seems that Quartus is encountering an error during startup relating to the tcl interpreter:
"error_message" : "A Tcl interpreter must exist before unregistering ::quartus::timing_assignment!",
"source_file" : "/quartus/mega/qsysipc/qsysipc_tcl_args_auto.cpp",
"line" : "3433",
"subsystem" : "QSYSIPC"
Has anybody encountered this error in the past, or have any suggestions on how to address it? Thanks!
- sstrell
The easiest thing to try would be to uninstall and then reinstall Quartus. Did it ever run successfully or has it always failed like this?
#iwork4intel
- MEIYAN_L_Intel
Have you try to uninstall and reinstall?
- MEIYAN_L_Intel
May I know any update?
- SClar25
Hi, Thanks for following up. The issue is resolved. I reinstalled and run the application using admin privileges. Thanks!
