Error occured when downloading .sof into device
We use Quartus 20.2 programmer to download a .sof file to device(1SX280LN3F43E2VG), by JTAG(usb-blaster), and meet the problem below:
Error (18950): Device has stopped receiving configuration data
Error (18948): Error message received from device: Detected bitstream error. Please make sure that the bitstream is compatible with the current Quartus version and device version. (Subcode 0x0040, Info 0x00000003, Location 0x0000A800)
Error (209012): Operation failed
The .sof file is generated by Quartus Prime Pro 20.2
I would like to know what happened and how to fix it, thank you!
- You can check the error and workaround for Quartus Pro 20.2 in the link below:
2.On top of that, please try to use latest version of Quartus Pro. Users should upgrade to the latest version of the Quartus.
https://fpgasoftware.intel.com/20.2/?edition=pro&platform=windows
Let me know if you need further information.
Aiman
- NurAiman_M_Intel
Aiman
- Shark121
Thank you for your answer!
Problem solved, the reason is input clock mismatched.
I change the configuration clock source(in "device and pin options") from 125MHz to internal or 25MHz, then it works. And I checked the schematic diagram, it's a 25MHz oscillator connected to OSC_CLK_1 pin
- NurAiman_M_Intel
Great to know that your issue is solved. I will proceed to close this case, however, if you need further support, you may open a new case in the future.
Aiman
