Error occured when downloading .sof into device
- 5 years ago
- You can check the error and workaround for Quartus Pro 20.2 in the link below:
2.On top of that, please try to use latest version of Quartus Pro. Users should upgrade to the latest version of the Quartus.
https://fpgasoftware.intel.com/20.2/?edition=pro&platform=windows
Let me know if you need further information.
Aiman
Aiman
- Shark1215 years ago
Thank you for your answer!
Problem solved, the reason is input clock mismatched.
I change the configuration clock source(in "device and pin options") from 125MHz to internal or 25MHz, then it works. And I checked the schematic diagram, it's a 25MHz oscillator connected to OSC_CLK_1 pin
