Error: No spd files are included in quartus project
- 5 years ago
Hi @syam404
May I know does my latest reply help?
Do you have further questions in regards to this case?
Richard Tan
Hi @syam404
1. Have you try to Generate HDL for your platform designer system? You will need to generate the files through platform designer.
2. You may use our simulator Modelsim Intel FPGA Edition (license required) or Modelsim Intel FPGA Starter Edition (no license required). https://fpgasoftware.intel.com/21.2/?edition=pro
3. Are you using the Intel IP? I would recommend to use HDL instead of block diagram to write your design as the design getting larger and complicated.
You may refer to the User Guide(UG) below to check the simulation flow.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf
You may test out the design example in the UG to learn how the simulation works.
Richard Tan
