15 years ago --- Quote Start --- I get the following error message when I try to simulate anything with Quartus: Error: Can't continue simulation because delay annotation information for design is missing I did edit "delay requirements" (under "assignments" -> "timing settings" ) after the error, and still get the same error. Is there anywhere else I can put this information in? Any ideas what I am missing? I have 3 different "programs" / assignments that I am getting this same error message on. Thanks for any advice! --- Quote End --- Hi, you have to run all processing step incl. the timing analysis. The missing delay information is extracted by the timing analyzer. Kind regards GPK
