18 years agoError Message Grey counter - Undefined entity
Hi, I try to implement a Grey counter for CycloneII.
I'm using Quartus 7.1. I think the VHDL code, please see below, is right. When I compile the code I get following error message: Error: Node instance "\create_lsb:1:createbit" instantiates undefined entity "gray_1" Does anybody know what I'm doing wrong? Thanks for the help! LIBRARY ieee; USE ieee.std_logic_1164.all; -- Entity Declaration Top Level ENTITY gray_n IS GENERIC(width: INTEGER :=3); PORT(async_rst, clock : IN STD_LOGIC; q : INOUT STD_LOGIC_VECTOR(width DOWNTO 0)); END gray_n; -- Architecture Body ARCHITECTURE archgray_n OF gray_n IS component gray_1 is PORT ( arst, clk, qin, zin : IN STD_LOGIC; qout : INOUT STD_LOGIC; zout : OUT STD_LOGIC); end component; -- inner interconnection of 1-bit sections signal z : STD_LOGIC_VECTOR(width DOWNTO 0); -- auxiliary signal for MSB signal qx : STD_LOGIC; BEGIN --less significant bits create_lsb : FOR i IN 1 TO width-1 GENERATE createbit : gray_1 PORT MAP (async_rst, clock, q(i-1), z(i-1), q(i), z(i)); end generate; -- most sigificant bits create_msb: gray_1 PORT MAP(async_rst, clock, qx, z(width-1), q(width), z(width)); --auxiliary signal for MSB qx <= q(width-1) or q(width); --parity bit generation ---------------------------------------------------------- process(async_rst, clock) begin if (async_rst ='1') then q(0) <= '1'; elsif(clock'event and clock = '1') then q(0) <= not q(0); end if; end process; z(0) <= '1'; end archgray_n;
