TChin5
7 years agoError message during Compile
I got a pop-up problem report and no error shown in my err/warning console window. Not sure what is the cause. I think it has to do with assigning LVDS to my signal. I did it as recommended by Inte...
Abe
7 years agoCan you share your design here. To use LVDS IO , you may have to use the ALTLVDS_TX and ALTLVDS_RX megafunctions and then the output of this megafunctions should be given to the IO which should be set as LVDS type.
