TChin5
7 years agoError message during Compile
I got a pop-up problem report and no error shown in my err/warning console window. Not sure what is the cause. I think it has to do with assigning LVDS to my signal. I did it as recommended by Inte...
Abe
7 years agoDo you want to use Emulated-LVDS or true LVDS? The IO standard you have chosen is Emulated-LVDS (LVDS_E-3R). To use true LVDS, select LVDS standard in Pin planner and then try.
Hopefully, when you are setting these pins as LVDS make sure the rest of the single-ended signals assigned on the same bank are all using the same voltage setting, ie if using LVDS 2.5, then the bank should be set at 2.5V for all other signals.
