TChin5
7 years agoError message during Compile
I got a pop-up problem report and no error shown in my err/warning console window. Not sure what is the cause. I think it has to do with assigning LVDS to my signal. I did it as recommended by Inte...
TChin5
7 years agoOnce I change the "OUT_P" to I/O standard=2.5v from LVDS_E_3R and removed the "OUT_P(P) signal. I was able to Compile successfully.
But again when I change "OUT_P" back to LVDS, Pin planner will automatically create "OUT_P(P) ..... then Compile failed again.
Quartus doesn't display any error message except the pop-up report problem window
I try to install the latest version of Quartus-lite V18.1 but still, same issue.
