9 years agoerror loading shared libraries: libaltera_s5_ref_mmd.so: cannot open shared obj
"Emulation Error : ./host: error while loading shared libraries: libaltera_s5_ref_mmd.so: cannot open shared object file: No such file or directory" I am trying to emulate an openCL design impl...
9 years agoThanks HRZ , i could eliminate the error with the information provided . It worked when both paths are assigned to LD_LIBRARY_PATH
I modified the Environment paths as following export ALTERAOCLSDKROOT=/eda/intel/16.1/hld export AOCL_BOARD_PACKAGE_ROOT=$ALTERAOCLSDKROOT/board/s5_ref export LD_LIBRARY_PATH=$ALTERAOCLSDKROOT/host/linux64/lib:$AOCL_BOARD_PACKAGE_ROOT/linux64/lib
