15 years agoError in Assembler
Hi All,
I encounter assembler error in Quartus 9.0 SP2. The error message is as following: How to fix it? Thank you. :) Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_lab.cpp, Line: 2560 num_matches == 1 Stack Trace: 0x230F66 : asm_assemble + 0x4DD6 (comp_asm) 0x23064C : asm_assemble + 0x44BC (comp_asm) 0x22F516 : asm_assemble + 0x3386 (comp_asm) 0x22C631 : asm_assemble + 0x4A1 (comp_asm) 0xCCFF : qexe_get_command_line + 0x26F (comp_qexe) 0x38E3 : QCU_ACF_SETTING::operator= + 0x11E3 (comp_qcu) 0x7C29 : QCU_FRAMEWORK::check_license + 0x139 (comp_qcu) 0xFBBD : qexe_process_cmdline_arguments + 0x34D (comp_qexe) End-trace Quartus II Version 9.0 Build 235 06/17/2009 SJ Full Version Service Pack Installed: 2
