riwerf
3 years agoError in altera_avalon_i2c.h
I have a problem with the NIOS code generation code:
We have a project where we use Quartus Prime 20.3p, but it also appears 22.2.0, and while checking the code quality we ran into an issue.
The...
KellyJialin_Goh
3 years agoHi,
Thank you for your feedback. Do try out on the 22.4 latest Quartus version at the mean time as it should eliminate the error. You could also go ahead with the workaround you suggested by deleting the semicolon.
Thank you and I shall set this case to close pending in the next few days.
Kelly
