Error ID: 138040 in Intel Quartus Prime ver. 17.1.0
Does any one know the message as below?
The message happened when I extracted the archived project and did Analysis & Synthesis.
I can't find spi_top.map.qxp_info in the folder.
Error (138040): The import file "../db/Top_tmp_qic_import/spi_top.map.qxp_info" created by Quartus Prime software module Version 17.1.1 Internal Build 593 12/11/2017 Patches 1.03std SJ Standard Edition cannot be used because it is incompatible with the current version of the Quartus Prime software
Can you share details on the Quartus design/project you're trying to compile. Alternatively , you could go to the project folder and delete the old DB (/db) folder and then try again. This issue may occur if you have used an internal build version to compile the project earlier and are now compiling using the standard releases.
- Abe
- HNing1
Thank for your recommend, I figured it out this issue.
It was compile through ver. 17.1.1.
Updated the software, then synthesis is work😊
