Error ID: 138040 in Intel Quartus Prime ver. 17.1.0
- 7 years ago
Can you share details on the Quartus design/project you're trying to compile. Alternatively , you could go to the project folder and delete the old DB (/db) folder and then try again. This issue may occur if you have used an internal build version to compile the project earlier and are now compiling using the standard releases.
Thank for your recommend, I figured it out this issue.
It was compile through ver. 17.1.1.
Updated the software, then synthesis is work😊
