11 years agoError glibc 2.4 not found quartus _sh required
I am a very new to quartus application and i am working as a system admin. I installed quartus 13 sp1. one of our developer trying to running a build but it giving below error please help to fix this error quartus_sh: /lib64/tls/libc.so.6: version `GLIBC_2.4' not found (required by quartus_sh) quartus_sh: /lib64/tls/libc.so.6: version `GLIBC_2.4' not found (required by quartus_sh) quartus_sh: /lib64/tls/libc.so.6: version `GLIBC_2.4' not found (required by quartus_sh) quartus_sh: /lib64/tls/libc.so.6: version `GLIBC_2.4' not found (required by quartus_sh) Warning (292006): Can't contact license server "@shuttle1" -- this server will be ignored Warning (292006): Can't contact license server "@shuttle2" -- this server will be ignored Warning (292006): Can't contact license server "@shuttle3" -- this server will be ignored Warning (292006): Can't contact license server "27001@vncin3" -- this server will be ignored Info: ******************************************************************* Info: Running Quartus II 64-Bit TimeQuest Timing Analyzer Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Full Version Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Wed Dec 24 20:15:01 2014 Info: Command: quartus_sta -t fpga_tpeside_report_timing.tcl ------------------------------------------------ ERROR: Can't run TimeQuest Timing Analyzer (quartus_sta) -- Fitter (quartus_fit) failed or was not run. Run the Fitter (quartus_fit) successfully before running the TimeQuest analyzer (create_timing_netlist). while executing "create_timing_netlist" (file "fpga_tpeside_report_timing.tcl" line 2) ------------------------------------------------ Error (23031): Evaluation of Tcl script fpga_tpeside_report_timing.tcl unsuccessful Error: Quartus II 64-Bit TimeQuest Timing Analyzer was unsuccessful. 1 error, 4 warnings Error: Peak virtual memory: 448 megabytes Error: Processing ended: Wed Dec 24 20:16:30 2014 Error: Elapsed time: 00:01:29 Error: Total CPU time (on all processors): 00:00:01
