Altera_ForumHonored Contributor17 years agoError from two signal going to one output I'm trying to make a pair of tristate buffers that are switched by an input as shown in the included picture. My problem is that I'm getting an error that says I cannot send two signals to the same o...Show More
Altera_ForumHonored Contributor17 years agoHi, just curious! why you tristating same one input twice? kaz
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
