9 years agoError: Failed to initialize the OpenCL/AAL system
When I use the command "aocl reprogram acl0 xx.aocx" to reprogram FPGA, it shows: aocl program: Running program from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libex...
9 years ago --- Quote Start --- When i input command 'aocl diagnose acl0'', it shows: aocl diagnose: Running diagnose from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libOSAL.so.0) /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libAAS.so.0) /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libOSAL.so.0) /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libAAS.so.0) aocl diagnose: failed. Does reinstall aocl can solve this problem? --- Quote End --- After i re ssh the FPGA server and run the command, it shows: aocl diagnose: Running diagnose from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec Error: Failed to initialize the OpenCL/AAL system. Error: Ensure a correct OpenCL image is programmed on the FPGA, and that the CCI driver has been loaded. AAL ASSERT( AAL ASSERT( m_pImplementation->IsOK() ) FAILED IsOK():Runtime.cpp:m_pImplementation->IsOK() ) FAILED aocl diagnose: failed 1 times. First error below: Using board package from vendor: Intel Corp Querying information for all supported devices that are installed on the host machine ... Do you know why?
