9 years agoError: Failed to initialize the OpenCL/AAL system
When I use the command "aocl reprogram acl0 xx.aocx" to reprogram FPGA, it shows: aocl program: Running program from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libex...
9 years ago --- Quote Start --- Did you update your OS kernel since then? If you update the kernel, you sometimes have to reinstall the driver. Try "aocl install", then reboot, then try "aocl diagnose acl0"; if it succeeded, retry your reprogram command. --- Quote End --- When i input command 'aocl diagnose acl0'', it shows: aocl diagnose: Running diagnose from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libOSAL.so.0) /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libAAS.so.0) /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libOSAL.so.0) /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec/diagnose: /root/altera_pro/16.0/quartus/dspba/backend/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/local/lib/libAAS.so.0) aocl diagnose: failed. Does reinstall aocl can solve this problem?
