9 years agoError: Failed to initialize the OpenCL/AAL system
When I use the command "aocl reprogram acl0 xx.aocx" to reprogram FPGA, it shows: aocl program: Running program from /root/altera_pro/16.0/hld/board/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libex...
9 years ago --- Quote Start --- Did you update your OS kernel since then? If you update the kernel, you sometimes have to reinstall the driver. Try "aocl install", then reboot, then try "aocl diagnose acl0"; if it succeeded, retry your reprogram command. --- Quote End --- I did not update anything!What is OS kernel?
